java error -program crash while running
Posted 5 sept. 2011, 05:32 UTC−4 Studies & Solvers Version 4.2 1 Reply
can someone help me with this error- here is the report - thanks David
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x25f50f92, pid=1480, tid=2628
# JRE version: 6.0_20-b02
# Java VM: Java HotSpot(TM) Client VM (16.3-b01 mixed mode windows-x86 )
# Problematic frame:
# C [flxmesh.dll+0x390f92]
# If you would like to submit a bug report, please visit:
# java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x24ca3400): JavaThread "pool-1-thread-1" [_thread_in_native, id=2628, stack(0x28c50000,0x28e50000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x317459dc
Registers:
EAX=0x0000ffff, EBX=0x2f0f6bc8, ECX=0x34d20148, EDX=0x317059e0
ESP=0x28e4a57c, EBP=0x28e4bb20, ESI=0x00000000, EDI=0x0000221c
EIP=0x25f50f92, EFLAGS=0x00210206
Top of Stack: (sp=0x28e4a57c)
0x28e4a57c: 1ac8323b 2e8aef80 00000010 00000000
0x28e4a58c: 2dd36b80 0000000c 00000001 00000000
0x28e4a59c: 00001347 00e4a66c 00000000 2dcb3468
0x28e4a5ac: 0091005d 00000002 00000004 2f2946a8
0x28e4a5bc: 00000000 00000003 01000003 2a9b4918
0x28e4a5cc: 00000018 00003eca 00410000 2dd32b88
0x28e4a5dc: 00000000 2aa796c0 3ff00000 7c9101e0
0x28e4a5ec: 2dd25c58 2dd25c68 2dd25c68 28e4a554
Instructions: (pc=0x25f50f92)
0x25f50f82: 81 3b c6 0f 8c 7c 00 00 00 8b 94 24 64 07 00 00
0x25f50f92: 8b 3c 82 3b fe 7c 6e 8b 43 04 8b 8c 24 e8 01 00
Stack: [0x28c50000,0x28e50000], sp=0x28e4a57c, free space=7e928e4a0b0k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.comsol.nativejni.solver.FlSolver.femTime(Lcom/comsol/nativejni/server/FlRunnable;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;Lcom/comsol/nativejni/CPointer;)V+0
j com.comsol.nativejni.solver.FlSolver.femTime(Lcom/comsol/nativejni/xmesh/Xmesh;Lcom/comsol/nativejni/util/Prop;Lcom/comsol/nativejni/util/Prop;Lcom/comsol/nativejni/xmesh/Solution;)V+23
j com.comsol.nativemph.a.c.a()V+52
j com.comsol.nativeutil.runnable.i.k()V+24
j com.comsol.solver.solution.SolverBase.a(Lcom/comsol/solver/d;Lcom/comsol/solver/d;Lcom/comsol/model/internal/SavePoint;Lcom/comsol/model/internal/XMeshNative;)V+267
j com.comsol.solver.solution.SolverTimeBase.a(Lcom/comsol/solver/d;Lcom/comsol/solver/d;Lcom/comsol/model/internal/SavePoint;Lcom/comsol/model/internal/XMeshNative;)V+116
j com.comsol.solver.solution.SolverBase.doExecute(Lcom/comsol/solver/d;)V+136
j com.comsol.solver.SolverOperation.execute(Lcom/comsol/model/internal/SolverSequence;Lcom/comsol/model/internal/SolverFeature;[Lcom/comsol/model/operations/ISolverPropCollector;)V+259
j com.comsol.model.internal.impl.SolverSequenceImpl.a(Ljava/lang/String;Ljava/lang/String;)V+251
j com.comsol.model.internal.impl.SolverSequenceImpl.g()V+52
j com.comsol.model.internal.impl.SolverSequenceImpl$aj.a(Lcom/comsol/model/internal/impl/SolverSequenceImpl;)Ljava/lang/Object;+146
j com.comsol.model.internal.impl.SolverSequenceImpl$aj.execute(Lorg/eclipse/emf/cdo/CDOObject;)Ljava/lang/Object;+5
J com.comsol.model.clientserver.ClientManagerImpl$e.call()Ljava/lang/Object;
j java.util.concurrent.FutureTask$Sync.innerRun()V+30
J java.util.concurrent.FutureTask.run()V
J java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Ljava/lang/Runnable;)V
j java.util.concurrent.ThreadPoolExecutor$Worker.run()V+28
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x24d74800 JavaThread "ModalContext" [_thread_blocked, id=2896, stack(0x2beb0000,0x2c0b0000)]
0x24ef6800 JavaThread "pool-4-thread-1" [_thread_blocked, id=3920, stack(0x2d5b0000,0x2d7b0000)]
0x246e1800 JavaThread "pool-7-thread-1" [_thread_blocked, id=2900, stack(0x2d3b0000,0x2d5b0000)]
0x2488ec00 JavaThread "Worker-3" [_thread_blocked, id=600, stack(0x2bb70000,0x2bd70000)]
0x24d3d800 JavaThread "Timer-0" [_thread_blocked, id=2704, stack(0x2acd0000,0x2aed0000)]
0x24dfdc00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3048, stack(0x2aad0000,0x2acd0000)]
0x24d71800 JavaThread "Worker-0" [_thread_blocked, id=2880, stack(0x295e0000,0x297e0000)]
=>0x24ca3400 JavaThread "pool-1-thread-1" [_thread_in_native, id=2628, stack(0x28c50000,0x28e50000)]
0x24c64400 JavaThread "Worker-JM" [_thread_blocked, id=3708, stack(0x253e0000,0x255e0000)]
0x249bdc00 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=1756, stack(0x249e0000,0x24be0000)]
0x23ac4400 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2840, stack(0x241f0000,0x243f0000)]
0x23a58800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=3868, stack(0x23ff0000,0x241f0000)]
0x22ca7800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3352, stack(0x23710000,0x23910000)]
0x22ca1800 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1852, stack(0x23610000,0x23710000)]
0x22ca0400 JavaThread "Attach Listener" daemon [_thread_blocked, id=808, stack(0x23410000,0x23610000)]
0x22c9a800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2424, stack(0x23210000,0x23410000)]
0x22c88000 JavaThread "Finalizer" daemon [_thread_blocked, id=2364, stack(0x23010000,0x23210000)]
0x22c83400 JavaThread "Reference Handler" daemon [_thread_blocked, id=2288, stack(0x22e10000,0x23010000)]
0x003c7000 JavaThread "main" [_thread_in_native, id=2408, stack(0x00040000,0x00140000)]
Other Threads:
0x22c80800 VMThread [stack: 0x22d10000,0x22e10000] [id=4016]
0x22cb2400 WatcherThread [stack: 0x23910000,0x23a10000] [id=2096]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 38592K, used 31490K [0x02a10000, 0x053f0000, 0x07f60000)
eden space 34304K, 91% used [0x02a10000, 0x048b2178, 0x04b90000)
from space 4288K, 2% used [0x04fc0000, 0x04fde698, 0x053f0000)
to space 4288K, 0% used [0x04b90000, 0x04b90000, 0x04fc0000)
tenured generation total 85648K, used 51388K [0x07f60000, 0x0d304000, 0x12a10000)
the space 85648K, 59% used [0x07f60000, 0x0b18f068, 0x0b18f200, 0x0d304000)
compacting perm gen total 47616K, used 47494K [0x12a10000, 0x15890000, 0x22a10000)
the space 47616K, 99% used [0x12a10000, 0x15871980, 0x15871a00, 0x15890000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x00426000 I:\comsol\COMSOL42\bin\win32\comsol.exe
0x7c900000 - 0x7c9b2000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll
0x7e410000 - 0x7e4a1000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll
0x773d0000 - 0x774d3000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\COMCTL32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\msvcrt.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f03000 C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.DLL
0x629c0000 - 0x629c9000 C:\WINDOWS\system32\LPK.DLL
0x74d90000 - 0x74dfb000 C:\WINDOWS\system32\USP10.dll
0x72000000 - 0x72022000 I:\comsol\COMSOL42\bin\win32\comsol_1312.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x6d800000 - 0x6da97000 I:\comsol\COMSOL42\java\win32\jre\bin\client\jvm.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x7c360000 - 0x7c3b6000 C:\WINDOWS\system32\MSVCR71.dll
0x6d7b0000 - 0x6d7bc000 I:\comsol\COMSOL42\java\win32\jre\bin\verify.dll
0x6d330000 - 0x6d34f000 I:\comsol\COMSOL42\java\win32\jre\bin\java.dll
0x6d290000 - 0x6d298000 I:\comsol\COMSOL42\java\win32\jre\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x6d7f0000 - 0x6d7ff000 I:\comsol\COMSOL42\java\win32\jre\bin\zip.dll
0x68000000 - 0x68036000 C:\WINDOWS\system32\rsaenh.dll
0x769c0000 - 0x76a74000 C:\WINDOWS\system32\USERENV.dll
0x5b860000 - 0x5b8b5000 C:\WINDOWS\system32\netapi32.dll
0x6d610000 - 0x6d623000 I:\comsol\COMSOL42\java\win32\jre\bin\net.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x71a50000 - 0x71a8f000 C:\WINDOWS\System32\mswsock.dll
0x76f20000 - 0x76f47000 C:\WINDOWS\system32\DNSAPI.dll
0x76d60000 - 0x76d79000 C:\WINDOWS\system32\iphlpapi.dll
0x76fb0000 - 0x76fb8000 C:\WINDOWS\System32\winrnr.dll
0x76f60000 - 0x76f8c000 C:\WINDOWS\system32\WLDAP32.dll
0x64000000 - 0x64025000 C:\Program Files\Bonjour\mdnsNSP.dll
0x76fc0000 - 0x76fc6000 C:\WINDOWS\system32\rasadhlp.dll
0x5ad70000 - 0x5ada8000 C:\WINDOWS\system32\uxtheme.dll
0x74720000 - 0x7476c000 C:\WINDOWS\system32\MSCTF.dll
0x23d90000 - 0x23d99000 C:\Documents and Settings\Administrator\Local Settings\Application Data\FLVService\lib\FLVSrvLib.dll
0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\SHELL32.dll
0x78520000 - 0x785c3000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCR90.dll
0x77b40000 - 0x77b62000 C:\WINDOWS\system32\apphelp.dll
0x755c0000 - 0x755ee000 C:\WINDOWS\system32\msctfime.ime
0x774e0000 - 0x7761e000 C:\WINDOWS\system32\ole32.dll
0x6d630000 - 0x6d639000 I:\comsol\COMSOL42\java\win32\jre\bin\nio.dll
0x24400000 - 0x24406000 I:\comsol\COMSOL42\lib\win32\cssystemutil.dll
0x78aa0000 - 0x78b5e000 C:\WINDOWS\system32\MSVCR100.dll
0x00010000 - 0x00015000 I:\comsol\COMSOL42\lib\win32\fldynload.dll
0x24430000 - 0x244d9000 I:\comsol\COMSOL42\lib\win32\flutil.dll
0x244e0000 - 0x2459c000 I:\comsol\COMSOL42\bin\win32\libiomp5md.dll
0x257e0000 - 0x259b0000 I:\comsol\COMSOL42\lib\win32\ipv4\flnutil.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\COMDLG32.dll
0x71ad0000 - 0x71ad9000 C:\WINDOWS\system32\WSOCK32.dll
0x78050000 - 0x780b9000 C:\WINDOWS\system32\MSVCP100.dll
0x259b0000 - 0x25b73000 I:\comsol\COMSOL42\lib\win32\fljni.dll
0x25b80000 - 0x25bb1000 I:\comsol\COMSOL42\lib\win32\flpost.dll
0x25bc0000 - 0x264bc000 I:\comsol\COMSOL42\lib\win32\flxmesh.dll
0x264c0000 - 0x267f4000 I:\comsol\COMSOL42\lib\win32\flmesh.dll
0x26800000 - 0x26bd4000 I:\comsol\COMSOL42\lib\win32\flgeom.dll
0x26be0000 - 0x26c07000 I:\comsol\COMSOL42\lib\win32\fldatacarrier.dll
0x26c10000 - 0x26e68000 I:\comsol\COMSOL42\lib\win32\flarray.dll
0x26e70000 - 0x26f00000 I:\comsol\COMSOL42\lib\win32\flfftw3.dll
0x26f00000 - 0x26f35000 I:\comsol\COMSOL42\lib\win32\flspecfun.dll
0x26f40000 - 0x27043000 I:\comsol\COMSOL42\bin\win32\libifcoremd.dll
0x27050000 - 0x2741e000 I:\comsol\COMSOL42\bin\win32\libmmd.dll
0x76c90000 - 0x76cb8000 C:\WINDOWS\system32\imagehlp.dll
0x27420000 - 0x27435000 I:\comsol\COMSOL42\lib\win32\flblas.dll
0x27440000 - 0x27456000 I:\comsol\COMSOL42\lib\win32\flcluster.dll
0x27460000 - 0x2746c000 I:\comsol\COMSOL42\lib\win32\clmpi.dll
0x27470000 - 0x2769d000 I:\comsol\COMSOL42\lib\win32\flsolver.dll
0x276a0000 - 0x276d8000 I:\comsol\COMSOL42\lib\win32\flclusterarray.dll
0x276e0000 - 0x2770a000 I:\comsol\COMSOL42\lib\win32\flarpack.dll
0x27710000 - 0x27801000 I:\comsol\COMSOL42\lib\win32\flspooles.dll
0x27810000 - 0x27839000 I:\comsol\COMSOL42\lib\win32\flcutil.dll
0x27840000 - 0x2784e000 I:\comsol\COMSOL42\lib\win32\sundials.dll
0x27a70000 - 0x27bcf000 I:\comsol\COMSOL42\lib\win32\flgraphics_common.dll
0x74810000 - 0x7497e000 C:\WINDOWS\system32\QUARTZ.dll
0x77120000 - 0x771ab000 C:\WINDOWS\system32\OLEAUT32.dll
0x75a70000 - 0x75a91000 C:\WINDOWS\system32\MSVFW32.dll
0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
0x75f40000 - 0x75f51000 C:\WINDOWS\system32\devenum.dll
0x77920000 - 0x77a13000 C:\WINDOWS\system32\setupapi.dll
0x76c30000 - 0x76c5e000 C:\WINDOWS\system32\WINTRUST.dll
0x77a80000 - 0x77b15000 C:\WINDOWS\system32\CRYPT32.dll
0x77b20000 - 0x77b32000 C:\WINDOWS\system32\MSASN1.dll
0x736b0000 - 0x736b7000 C:\WINDOWS\system32\msdmo.dll
0x27c10000 - 0x27c47000 C:\WINDOWS\system32\qasf.dll
0x53800000 - 0x538c4000 C:\WINDOWS\system32\wmvdmoe.dll
0x59090000 - 0x590ae000 C:\WINDOWS\system32\wmsdmoe.dll
0x27c50000 - 0x27d8b000 C:\WINDOWS\system32\wmvdmoe2.dll
0x27d90000 - 0x27e3f000 C:\WINDOWS\system32\wmv8dmoe.dll
0x27e40000 - 0x2800c000 C:\WINDOWS\system32\WMVADVE.DLL
0x28010000 - 0x28167000 C:\WINDOWS\system32\wmsdmoe2.dll
0x5dfe0000 - 0x5e028000 C:\WINDOWS\system32\qdv.dll
0x73870000 - 0x73934000 C:\WINDOWS\system32\ir50_32.dll
0x28680000 - 0x28776000 C:\Program Files\Common Files\Ahead\DSFilter\NeNDVid.ax
0x28790000 - 0x28a00000 C:\Program Files\Common Files\Ahead\Lib\AdvrCntr.dll
0x3d930000 - 0x3da16000 C:\WINDOWS\system32\WININET.dll
0x28a00000 - 0x28a09000 C:\WINDOWS\system32\Normaliz.dll
0x78130000 - 0x78263000 C:\WINDOWS\system32\urlmon.dll
0x3dfd0000 - 0x3e1b9000 C:\WINDOWS\system32\iertutil.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x757f0000 - 0x75822000 C:\WINDOWS\system32\qcap.dll
0x28e50000 - 0x28eb3000 C:\Documents and Settings\Administrator\.comsol\v42\configuration\comsol\org.eclipse.osgi\bundles\172\1\.cp\swt-win32-3659.dll
0x28ee0000 - 0x28efd000 C:\Documents and Settings\Administrator\.comsol\v42\configuration\comsol\org.eclipse.osgi\bundles\172\1\.cp\swt-gdip-win32-3659.dll
0x4ec50000 - 0x4edfb000 C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22509_x-ww_c7dad023\gdiplus.dll
0x74c80000 - 0x74cac000 C:\WINDOWS\system32\oleacc.dll
0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
0x29980000 - 0x29c45000 C:\WINDOWS\system32\xpsp2res.dll
0x29e60000 - 0x29ef9000 I:\comsol\COMSOL42\lib\win32\flgraphics_swt_sw.dll
0x29f00000 - 0x2a107000 I:\comsol\COMSOL42\lib\win32\fl3d_indirect_sw.dll
0x2a110000 - 0x2a1a9000 I:\comsol\COMSOL42\lib\win32\fltextrenderer.dll
0x2a1b0000 - 0x2a1bb000 I:\comsol\COMSOL42\lib\win32\fljnitextrenderer.dll
0x6d000000 - 0x6d14a000 I:\comsol\COMSOL42\java\win32\jre\bin\awt.dll
0x75cf0000 - 0x75d81000 C:\WINDOWS\system32\mlang.dll
0x76380000 - 0x76385000 C:\WINDOWS\system32\msimg32.dll
0x77a20000 - 0x77a74000 C:\WINDOWS\System32\cscui.dll
0x76600000 - 0x7661d000 C:\WINDOWS\System32\CSCDLL.dll
0x75f80000 - 0x7607d000 C:\WINDOWS\system32\browseui.dll
0x76990000 - 0x769b5000 C:\WINDOWS\system32\ntshrui.dll
0x76b20000 - 0x76b31000 C:\WINDOWS\system32\ATL.DLL
0x7e290000 - 0x7e401000 C:\WINDOWS\system32\shdocvw.dll
0x754d0000 - 0x75550000 C:\WINDOWS\system32\CRYPTUI.dll
0x2aed0000 - 0x2af33000 C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\PDFShell.dll
0x78480000 - 0x7850e000 C:\WINDOWS\WinSxS\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_6f74963e\MSVCP90.dll
0x2c570000 - 0x2cfe8000 I:\comsol\COMSOL42\lib\win32\flmklblas.dll
VM Arguments:
jvm_args: -Dosgi.splashPath=platform:/base/plugins/com.comsol.util/ -Dosgi.clean=true -Dosgi.configuration.cascaded=true -Dosgi.checkConfiguration=true -Dosgi.sharedConfiguration.area=file:configuration/comsol -Dosgi.sharedConfiguration.area.readOnly=true -Dosgi.configuration.area=@user.home/.comsol/v42/configuration/comsol -Dosgi.instance.area=@user.home/.comsol/v42/workspace/comsol -Dcs.logoutput=file -Dcs.logfileprefix=comsol -Dcs.client=true -Xss2m -Xms40m -Xmx256m -XX:MaxPermSize=256m
java_command: <unknown>
Launcher Type: generic
Environment Variables:
CLASSPATH=.;C:\Program Files\Java\jre6\lib\ext\QTJava.zip
PATH=I:\comsol\COMSOL42\bin\win32;I:\comsol\COMSOL42\lib\win32;I:\comsol\COMSOL42\lib\win32\ipv4;I:\comsol\COMSOL42\ext\cadimport\win32;I:/comsol/COMSOL42/bin/win32//../../java/win32/jre/bin/client;I:/comsol/COMSOL42/bin/win32//../../java/win32/jre/bin;I:/comsol/COMSOL42/bin/win32//../../java/win32/jre/lib/i386;C:\Program Files\Silverfrost\FTN95;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;I:\elmer\Elmer6.2\lib;I:\elmer\Elmer6.2\bin;I:\comsol\COMSOL42;
USERNAME=Administrator
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 4 Stepping 1, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (1 cores per cpu, 2 threads per core) family 15 model 4 stepping 1, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ht
Memory: 4k page, physical 2095848k(977136k free), swap 4034324k(2957784k free)
vm_info: Java HotSpot(TM) Client VM (16.3-b01) for windows-x86 JRE (1.6.0_20-b02), built on Apr 12 2010 13:52:23 by "java_re" with MS VC++ 7.1 (VS2003)
time: Mon Sep 05 12:01:39 2011
elapsed time: 642 seconds
1 Reply Last Post 6 sept. 2011, 02:12 UTC−4
