Help! Getting stress out of an AC/DC Model
Hello!
I am working on a model of a cylindrical conductive coil, modeled as an axisymmetric 2D model. It has a current run through it that generates a magnetic field and puts a load on the coil. I found a very useful example in the help files of how to generate the field and to find forces in the coil, using three coupled multiphysics: parametized geometry (pg), sensitivity analysis (sa), and azimuthal induction currents (emqa). However, the problem is that I want to find what the stresses are in the coil due to this loading. I am under the impression it would involve coupling a stress-strain multiphysics to it, but every attempt I have made so far brings up an error and will not run. I have attached a file with the geometry simplified with only 4 turns and no insulation instead of the complete 16 turn coil. Any help getting stress out of this model would be greatly appreciated! I do not think this would be a very hard problem, but for some reason (probably because I am a very new FEA user) I cannot get it. Thank you in advance for your help.
0 Replies Last Post 16 déc. 2009, 09:53 UTC−5
Hello Chance Donahue
