2 sept. 2011, 03:43 UTC−4
If you are talking about electrical impedance it is as simple as: Impedance = Voltage / Current. In gerneral everthing is complex.
Cheers
Edgar
Cheers
Edgar
2 sept. 2011, 09:04 UTC−4
Hello Edgar,
How do I calculate the current (I)?
i am using I=intop1(2*pi*r*pzd.Jz)...take a look (file .docx), but i have not results for current (I)
thanks for your reply
Hello Edgar,
2 sept. 2011, 09:43 UTC−4
Arlindo,
it seems you are integrating across boundary 3, which is on the symmetry axis. I think you must integrate across the interface between the brass electrode and the piezo disc.
Cheers
Edgar
Arlindo,
Cheers
Edgar
2 sept. 2011, 10:14 UTC−4
Edgar,
Take a look !
Tkanks,
Arlindo
Edgar,
Take a look !
Tkanks,
Arlindo
10 years ago
22 nov. 2014, 00:18 UTC−5
Hi Adlindo
Have you solved your question? I confront the same one as you, and I also found that many persons have those question of peizoelectric impedance. should someone can give us a simple modle to solve this problem.
Hi Adlindo
8 years ago
17 nov. 2016, 22:55 UTC−5
Now im doing my final year project. and its about formulation theory impedance in increasing power output of piezoelectric. The problem is till now i cant find any formula for impedance piezoelectric. can you help me to give any info or anything that related with impedance piezoelectric. i am really need it.
