continuing a simulation
If I have a time dependent model that ran OK say from 0 to 50 microsecs and I wish to continue
the simulation from 50 to 100 microsecs.
How is this done?
thanks
David
3 Replies Last Post 31 août 2011, 10:30 UTC−4
Posted: 1 decade ago 31 août 2011, 09:28 UTC−4
How is this done?
thanks
David
Hi David
Not sure if I answer what you are asking for, but if you set your solution as your initial values/start conditions and solve for 50 more microseconds my thought would be that this is what you want.
Nils E
[QUOTE] Hi If I have a time dependent model that ran OK say from 0 to 50 microsecs and I wish to continue the simulation from 50 to 100 microsecs. How is this done? thanks David [/QUOTE] Hi David Not sure if I answer what you are asking for, but if you set your solution as your initial values/start conditions and solve for 50 more microseconds my thought would be that this is what you want. Nils E
Posted: 1 decade ago 31 août 2011, 10:01 UTC−4
How do you set a solution as an initial start condition?
Hi How do you set a solution as an initial start condition?
Posted: 1 decade ago 31 août 2011, 10:30 UTC−4
if you run a first i.e. stationary solver then "store the data" (specific solver node set manually or directly by COMSOL when 2 solvers are added in sequence) and start next solver with the "Stored solution" as "initial conditions" then I believe you have your study sequence
Hi if you run a first i.e. stationary solver then "store the data" (specific solver node set manually or directly by COMSOL when 2 solvers are added in sequence) and start next solver with the "Stored solution" as "initial conditions" then I believe you have your study sequence -- Good luck Ivar
