Hello Leanne Nixon
6 déc. 2011, 09:37 UTC−5
I also have the same problem in 4.2.a version. Any suggestion? I am using structural mechanics module.
Marjan
Marjan
Magnus Ringh
COMSOL Employee
6 déc. 2011, 10:27 UTC−5
Make sure that all differentiation operators in the model have valid variable names as their second argument (the variable that you differentiate with respect to). For example,
d(x*y,x)
is valid but
d(x*y,1) or d(x*y,2*x)
give the error that you report.
Magnus Ringh, COMSOL
d(x*y,x)
is valid but
6 déc. 2011, 10:48 UTC−5
Hi again,
Thanks for the reply. I solved it by removing the check mark for nearly in-compressible material. I did not have any analytic function that uses d function.
Yours,
Marjan
Hi again,
Yours,
Marjan
9 déc. 2011, 05:56 UTC−5
Hi, I am just using 4.2a. and wish to know more about it.
When i formulate the hyperelastic material using Mooney Rivlin material,
the same error pop up.
May I know why Mooney Rivlin material will be involve into problem?
as i use Neo hookean material, all the things done smoothly.
Lars Gregersen
COMSOL Employee
9 déc. 2011, 06:41 UTC−5
You should try the update for Comsol 4.2a:
www.comsol.com/support/updates
It solves a specific problem with the structural mechanics module that causes this problem.
Lars Gregersen
Comsol Denmark
http://www.comsol.com/support/updates
Lars Gregersen
Comsol Denmark
9 déc. 2011, 07:00 UTC−5
Dear Lars Gregersen ,
Thank you.
I will try it on monday,as now do not have comsol in my computer.
will update you all information whether i solve it or not.
Thank you.
11 janv. 2012, 05:18 UTC−5
Dear All,
I can confirm that this problem is removed by the Update 2.
Peter
Dear All,
Peter
