how to make a triangle in comsol 3.5a
Dear users,
Does anyone know how to make a triangle in comsol 3.5a. Any help will be highly regarded.
thanks.
Cecil
4 Replies Last Post 5 août 2013, 13:38 UTC−4
Posted: 1 decade ago 18 août 2011, 01:57 UTC−4
draw lines close to the values you want with a mouse, then edit the numerical values the the final desired ones.
if its a right angle, draw a box, add the diagonal, then split the curve and keep only the three desired, combine the lines into a "solid"
Hi draw lines close to the values you want with a mouse, then edit the numerical values the the final desired ones. if its a right angle, draw a box, add the diagonal, then split the curve and keep only the three desired, combine the lines into a "solid" ... -- Good luck Ivar
Yashar Entezarghofran
Posted: 1 decade ago 5 août 2013, 13:01 UTC−4
I think the easy way is to select to draw a Polygen but you can set three point out of the five to sit on eachother, this way it will become a triangle.
Regards
Yashar
I think the easy way is to select to draw a Polygen but you can set three point out of the five to sit on eachother, this way it will become a triangle. Regards Yashar
Posted: 1 decade ago 5 août 2013, 13:32 UTC−4
Use polygon feature. Define the x,y or (r,z) coordinates for the 3 points in the right order. Plot. This should work.
Posted: 1 decade ago 5 août 2013, 13:38 UTC−4
Sorry. i work on 4.3.
