Incident field confusion
Dear Sir/Madam,
I'm a freshman in RF module, and would like to try a very simple and straightforward case first so I can move to more complicated case later:
modeling how light (i.e., electromagnetic wave) is absorbed inside a metal oxide layer (~0.5 mm).
I'm not sure how can I deal with the boundary conditions and set the light source.
1) I tried draw a close box by using Bezier polygon, and set top line be the source using electric field or scattering boundary condition (set amplitude 1 V/m), but the modeling result show nothing (green-colored box instead of any rainbow color).
2) I also tried to stack one thin rectangle as source (set non-zero initial value) on the top of rectangle of my sample. But the sample show dark blue which means zero . It doesn't make sense since the sample should absorb some light.
The answer may be really simple, but I cannot get any help from my working environment. So I would really appreciate you help! Thanks,
1 Reply Last Post 14 août 2011, 04:32 UTC−4
Posted: 1 decade ago 14 août 2011, 04:32 UTC−4
indeed its good to start with a simple example (and to run the examples in the model library). from what I understand you seem to have no "source" of EM energy, ou need to have a radiating source in there defined i.e by a voltage.
read trhough some of the simple RF or optics examples
Hi indeed its good to start with a simple example (and to run the examples in the model library). from what I understand you seem to have no "source" of EM energy, ou need to have a radiating source in there defined i.e by a voltage. read trhough some of the simple RF or optics examples -- Good luck Ivar
