13 août 2011, 13:57 UTC−4
you have different options, a geometrical point, defined as the intersection of two (or more) lines will enforce a "hard point" node during the meshing. You can also use the "distribution" subnode in COMSOL Mesh nodes, to define the coordinates of nodes along a line etc
These appraoches have always been sufficient for my meshing cases
15 août 2011, 06:55 UTC−4
Hi Ivar,
Thank you for the information. But can you please help me by elaborating this method by using the 'Distribution' subnode in Mesh.
Actually, I have a 3D model of a solid rotor. I extracted the co-ordinates of the mesh through MATLAB. Through a simple MATLAB script I got the the co-ordinates of the nodes in one of the cross-section of the rotor (i.e. in z=0 plane). Now I want to use those co-ordinates ( x & y co-ordinates) to draw a mesh on the 2D model of the same rotor ( that would somehow be a simple circle in which I would like to create a mesh).
I am obliged to have your suggestion previously and will appreciate it if you could help me again.
Thanks in advance!
Hi Ivar,
Thanks in advance!
17 août 2011, 02:16 UTC−4
COMSOL is not really set up to work on the meshing like that. Why exactly do you want to access the nodes to copy the mesh like that ?. You have the "copy" mesh function in the mesher, if you are working on the same geometry.
As in COMSOL you define the physics on the geometric "Entities" the mesh does not have the same importance than in older FEM programmes, where everything was "fixed onto the mesh", and meshing was the first operation done
