Variable limits of integration with Postint
Yesterday I started to use Comsol with Matlab. I need to compute a moving window average of the comsol results, so I integrate
vyint=postint(fem,'v*(x>xlow)*(x<xup)*(y>ylow)*(y<yup)', ...
where the limits of integration are variable (xlow, etc). When I use this with fixed limits of integration there is no problem. When I switch to variable limits I get an error
??? Java exception occurred:
Exception:
com.femlab.server.MlError: Error using ==> feval
Undefined function or method 'ylow' for input arguments of type 'double'.
(rethrown as com.femlab.jni.FlNativeException)
Failed to evaluate expression
- Expression: v*(x>xlow)*(x<xup)*(y>ylow)*(y<yup)
Failed to evaluate variable
- Variable: xlow
- Geometry: 1
- Subdomain: 1
Post expr failed
So I guess I need to define xlow, etc. in Comsol as another variable. Is this guess right? If so, how to implement it? How else can this problem be solved?
1 Reply Last Post 18 janv. 2010, 08:25 UTC−5
Hello Eric Morales
Artemio Plana-Fattori
Posted: 2 decades ago 18 janv. 2010, 08:25 UTC−5
Just starting with COMSOL & MATLAB, I found your question very useful... because it did help me to clarify the syntax to use in integrating over sub-domains.
Effectively, COMSOL doesn't understand your variables "xlow", "xup", "ylow" and "yup". You can parameterize these limits by using an intermediate variable:
xlow = 1; xup = 2;
ylow = 3; yup = 4;
domain = sprintf('u*(x>%d)*(x<%d)*(y>%d)*(y<%d)', xlow, xup, ylow, yup);
postint(fem,domain)
Values 1, 2, 3, and 4 are arbitrary, you can define the four limits according to your problem.
Best regards.
Hello, Just starting with COMSOL & MATLAB, I found your question very useful... because it did help me to clarify the syntax to use in integrating over sub-domains. Effectively, COMSOL doesn't understand your variables "xlow", "xup", "ylow" and "yup". You can parameterize these limits by using an intermediate variable: xlow = 1; xup = 2; ylow = 3; yup = 4; domain = sprintf('u*(x>%d)*(x%d)*(y
