3 août 2011, 04:51 UTC−4
I use the java code de COMSOL 4.2 in Eclipse/Java,
Only, I import two packages
import com.comsol.model.*;
import com.comsol.model.util.*;
And, I add the *.jars (C:\Program Files\COMSOL42\plugins) in the library buiding-project of Eclipse,
Aron
Aron
3 août 2011, 12:18 UTC−4
Hi Alex,
I have installed Comsol 4.2, generated the Java source file for the feeder_clamp model, and created the Eclipse project as described in the documentation.
When I open the compiled .class file (it can be found in the bin directory of the project) from the Comsol Desktop, the model is loaded and a graphic of a mechanical part is generated. I don't know if you have tried this, but it's an easy way of running the Java model.
However, if I follow the instructions to execute the Java model from Eclipse, and using the Comsol server, when I run the Java application a message is displayed in the server window indicating that a client is connecting, and after a while another message indicates that the client is disconnecting, but nothing more happens... I have followed all the instructions given in the documentation to configure the Eclipse project, i.e. adding the libraries to the project, and adding the two lines in the main method for connecting to the Comsol server, but it doesn't say the expected behaviour when you proceed so...
Do you have any more idea?
Best regards.
P.D.: I'm the Ana's colleague at the CSIC in Spain.
Hi Alex,
Best regards.
9 years ago
23 nov. 2015, 10:43 UTC−5
Hello Nacho,
this is normal behaviour. You do not see anything if you run your java file in Eclipse. If you want to see something you have to use the Graphical User Interface which is described in "COMSOL Multiphyiscs/COMSOL Multiphisics Programming Reference Manual/Graphical User Interfaces" in the documentation.
I know that this post is old but I'm answering for descendants.
Best regards
Michael
Hello Nacho,
Best regards
Michael
9 years ago
2 juin 2016, 02:49 UTC−4
Hi Michael:
Can you tell me where to find the COMSOL API user guide? I would great appreciate if you could help me.
Best regards
rene
Hi Michael:
Best regards
rene
Jeff Hiller
COMSOL Employee
9 years ago
2 juin 2016, 08:52 UTC−4
All manuals for your installation are accessed in the GUI through File > Help > Documentation, and in the doc subdirectory in your installation directory (Usually C:/Program Files/COMSOL/COMSOL52/Multiphysics/doc/ on Windows)
9 years ago
15 août 2016, 11:17 UTC−4
Hi Jeff,
I'm trying to add the java file generated by COMSOL to my NetBeans project. It calls for these two imports:
import com.comsol.model.Model;
It is not clear, however, which jar files need to be added to my project to provide the information required. Can you point me to the correct jar files?
Herb Smith
Hi Jeff,
Herb Smith
Lars Gregersen
COMSOL Employee
9 years ago
16 août 2016, 02:41 UTC−4
In the Programming Reference Manual in the chapter "Graphical User Interfaces" it says:
"Go to the Libraries tab and click Add External JARs. Add all the JAR files placed in the plugins directory under the COMSOL Multiphysics installation directory (typically
C:\Program Files\COMSOL\COMSOL52a\Multiphysics\plugins)."
I'm sure that there is a similar procedure for NetBeans.
Lars Gregersen
Comsol Denmark
Lars Gregersen
Comsol Denmark
