Negative mass fraction problem
Hi all,
I am trying to simulate a furnace that has combustion reaction using a stationary solver. I use eddy dissipation model. Turbulence is modeled using k-eps model. I use transport of concentrated species module from COMSOL. For the given values of velocity and mass fraction as boundary condition, I get negative mass fractions of chemical species after convergence. I read the COMSOL knowledge base about avoding negative concentrations. The mesh refining solution works when the boundary condition of velocity if lowered. However, for required boundary condition of velocity, I still have a problem. I also tried using auxilary sweeping velocity from lower to required velocity value.
Thank you in advance!
Regards, Prajakta Nakate TU Delft Netherlands
0 Replies Last Post 12 nov. 2018, 09:18 UTC−5
Hello Prajakta Nakate
