Steady state Vs Transient problem in Shell model
Dear All,
I have simulated a resistive heater model (1200um x 80000um; width of heating element- 50 um) and used the shell model approximation by coupling 'Electric current, Shell' and 'Conjugate heat transfer' physics to incorporate the joule heating effect.
I have done the steady state analysis wherein I have obtained a temp of 293.16K compared to the normal temp of 293.15K i.e. an increment of just 0.01K with a fluid flow and i/p voltage of 1V. However, transient analysis of the same for 0.02s gave a max temp of about 45000K with the same flow. I would like to know why their is such a huge temperature difference coming up?
The range settings for transient analysis for 0.02s were- range (0, 0.001,0.02) and it took about 12.5 hrs to compute. Here the convergence plot showed saturation after about 100 time steps corresponding to 0.005 sec. Thus I had also set a diff settings of range (0, 0.0005,0.005) which took about 5 hrs to compute. In none of the cases the graph plot for temperature vs time is saturating although the convergence plot showed a saturation value. Hence I think the it needs to solve for a greater time for the transient analysis to complete. However it is taking quiet a long time to do so. I shall be highly obliged if anyone can kindly help me with the above problem to solve the above temerature ambiguity and longer solution time.
Looking forward for your help,
Debashis
0 Replies Last Post 29 juil. 2011, 08:24 UTC−4
Hello DEBASHIS MAJI
