How to take into consideration shear waves
Hello, Please help me.
In acoustics module, how do we specify that specific domains are solid. In order to take into consideration the shear waves. I am using pressure acoustics, frequency domain physics, like the tutorial ''ultrasound induced heating''.
Thanks in advance,
Nesma
2 Replies Last Post 13 déc. 2018, 09:52 UTC−5
Hello Nesma El Sayed
Posted: 6 years ago 13 déc. 2018, 09:45 UTC−5
Hi, Nesma El Sayed This problem has also been bothering me. I have not observed shear waves in the time domain signals I extracted. If you know how to solve this problem, wish you share it with me.
Thank you!
Dan
Hi, Nesma El Sayed This problem has also been bothering me. I have not observed shear waves in the time domain signals I extracted. If you know how to solve this problem, wish you share it with me. Thank you! Dan
Posted: 6 years ago 13 déc. 2018, 09:52 UTC−5
Hi Dan,
I figured out that you need to couple solid mechanics with pressure acoustics and use the built-in multiphysics feature acoustic-structure. Then you will see how the pressure wave will transform into elastic wave in the solid domain. I have done this study in the frequency domain.
I don't know if this help you but tell me if you have other questions
Nesma
Hi Dan, I figured out that you need to couple solid mechanics with pressure acoustics and use the built-in multiphysics feature acoustic-structure. Then you will see how the pressure wave will transform into elastic wave in the solid domain. I have done this study in the frequency domain. I don't know if this help you but tell me if you have other questions Nesma
