Assigning materials to domains from MATLAB
Dear COMSOL experts,
I am wondering how to assign materials to domains from a matlab script. For example, I create a block "my_block" with
>> model.geom('geom1').feature.create('my_block', 'Block');
>> ... % define the properties of block here
Then I create a material called "superconductor" with
>> model.material.create('superconductor');
Now, if I assign the "my_block" to material "superconductor" through COMSOL GUI and save the result as m file, the assignment will look like this:
>> model.material('superconductor').selection.set([1]);
How do I find out programatically the correspondence between "my_block" and the number 1 that I need to specify as the parameter to the last command.
Thanks in advance,
Andrey
3 Replies Last Post 10 févr. 2017, 05:36 UTC−5
Hello Andrey Zhdanov
Posted: 8 years ago 13 oct. 2016, 07:19 UTC−4
Dear Andrey Zhdanov
I was stuck at the same point. Did you find the way to solve it
I would be glad if you let me know
Prem
Dear Andrey Zhdanov I was stuck at the same point. Did you find the way to solve it I would be glad if you let me know Thanks Prem
Posted: 8 years ago 9 févr. 2017, 06:59 UTC−5
I was stuck also here, How could I program in Matlab like such sentence:
model.material('mat2').selection.set('block1');
instead of:
model.material('mat2').selection.set([1]);
For now my problem is that the domain [1] maybe not exact block 1 I wanted to select. I generated some random distribution of the geometries.
if anyone knows the answer, It would be a great help for my work.
best regards,
Guanda Yang
I was stuck also here, How could I program in Matlab like such sentence: model.material('mat2').selection.set('block1'); instead of: model.material('mat2').selection.set([1]); For now my problem is that the domain [1] maybe not exact block 1 I wanted to select. I generated some random distribution of the geometries. if anyone knows the answer, It would be a great help for my work. best regards, Guanda Yang
Posted: 8 years ago 10 févr. 2017, 05:36 UTC−5
This blog post should contain some useful information for you:
www.comsol.dk/blogs/automatically-handling-selections-comsol-multiphysics/
If you are still having problems then please send your model and M-files to support and we will try to help you.
Lars Gregersen
Comsol Denmark
Hi This blog post should contain some useful information for you: https://www.comsol.dk/blogs/automatically-handling-selections-comsol-multiphysics/ If you are still having problems then please send your model and M-files to support and we will try to help you. -- Lars Gregersen Comsol Denmark
