Mesh problem
Hello, NEW TO COMSOL. I had a 2D geometry and I changed it to 3D geometry. Now, I have found some problems with meshing and I couldn't use physics-controlled mesh. The errors are as follow: Failed to generate mesh for domain. - Domain: 2 Failed to respect edge element on geometry edge. - Edge: 210 Failed to move mesh point in domain. - x-coordinate: 0.00157114 - y-coordinate: -1.8e-005 - z-coordinate: 5e-006 Could you please help me?
1 Reply Last Post 16 sept. 2018, 17:57 UTC−4
Posted: 7 years ago 16 sept. 2018, 17:57 UTC−4
There are many possible reasons why meshing can fail. If possible, upload your model to this forum so that others can look at it. They may then be able to identify the cause of your problem and may even be able to suggest a way to correct it.
