where is the B field?
Posted 12 juil. 2011, 12:36 UTC−4 Low-Frequency Electromagnetics Version 4.1 9 Replies
I have an axial current in 2D in the ACDC mf mode. External current in z direction.
Results: current in z direction, no B field in surrounding air.
I realized maybe the circuit is not closed so I tried various boundaries with no luck
help anyone
without having seen your model: I think you should define the domain as a "single turn coil domain" and choose the current there.
I think the problem with the external current density is, as you said, that the loop is not closed.
Do you get any Resistant losses with the ext. current density? I don't think so.
With the single turn coil domain you get them and the field.
Greetings
Thanks but the single coil domain is for azimuthal currents and I have an axial current
I don't think you must close an external current inside the model. You should indeed see a magnetic field with a phi component (in axial symmetry) or x and y components in planar symmetry.
Cheers
Edgar
Hey,
to be sure we don't talk at cross purposes:
Are you trying to simulate it in a 2D axis symmetric system or a normal 2D system?
I understood it as a normal 2D system.
When you say "axial current", do you mean a current flowing into z-direction, or do you mean a tangential (phi-direction) flowing current (for example around the z-axis)?
Because I understood it as a flow into z-direction.
When you say "external current", do you mean "external current density", or do you couple your model with e.g. the electrical circuit physics?
IF you want to let it flow into z-direction in 2D, a "single turn coil domain" works (Az and Resistant Losses are not zero) [not only at azimuthal currents]. As far as I know, the "external current density" doesn't work here (Az and Resistant Losses are zero).
IF you want to let it flow around the z-axis, you can define it with only a phi- component in a cylindrical system, or stay in cartesian coordinates and use parametric circle equations.
Perhaps I'm just having a wrong image of you model in my mind. Could you maybe attach it?
Greetings
thanks for your interest
the system is 2D axisymmetric, the current flows in the z direction, I am trying to see the B field surrounding this current.
attached is a file with the simple geometry, I inject external current density but see no B field.
thanks
David
thanks
David
In a 2D-Axisymmetric analysis, z is the height on your screen (up-down), and phi is the vector that goes into your screen. This is the component that you want: set Jphi to some non-zero value.
I have two more tips for your model:
1. Create a large rectangle around the block so that the surrounding field can be calculated correctly. Make sure that there is enough space for the field to be reduced to 5-10% of their maximum value, preferably more.
2: Refine your mesh.
I hope that helps.
Ruud
I think he wants a current in z-direction, not phi. This should generate a Bphi field, but it doesn't in the model.
Is it possible to set an external current density in z direction?
Cheers
Edgar
Suggested Content
- KNOWLEDGE BASE Two-Phase Flow Modeling Guidelines
- FORUM not sure where the problem is
- FORUM Where to start
- BLOG Microwave Plasmas
- BLOG How to Model Linear and Nonlinear Optics in the COMSOL® Software
