Mickaël Barsive
COMSOL Employee
7 years ago
28 août 2018, 08:44 UTC−4
Updated:
7 years ago
28 août 2018, 08:58 UTC−4
I could advice you to have a look on a tutorial model using BH curve such as the "Ecore Transformer": https://www.comsol.fr/model/e-core-transformer-14123
Under the node "Soft Iron (without losses)" in "Material" you will find how a BH curve is defined in COMSOL Multiphysics using "Interpolation" function.
In your case, you could use the "From file" option in "Interpolation" to import your data from a csv file.
I hope this helps.
Please contact the COMSOL technical support for more details.
Mickaël
I hope this helps.
Mickaël
7 years ago
30 août 2018, 05:13 UTC−4
Updated:
7 years ago
30 août 2018, 08:15 UTC−4
Hello sir,
i tried to do the same. but i am getting error 'Failed to find a solution''Singular matrix'' '.
here i am attaching the following files.
1. with normal soft iron for (domain-2)
2. HB,BH values changed file
3. BH data.
please look in to it and give the solution. Thanking you
Hello sir,
3. BH data.
Mickaël Barsive
COMSOL Employee
7 years ago
30 août 2018, 08:21 UTC−4
Updated:
7 years ago
30 août 2018, 08:28 UTC−4
For this kind of question, please contact the COMSOL technical support.
Usually in "Magnetic field (mf)" interface you can meet this error in time or frequency domain when the electrical conductivity of air is stricly null (try with 0.1[S/m] for example).
Mickaël
Mickaël
