Solid Fluid Interaction, Fixed geometry
Is it possible to apply a Rigid connector in Solid Fluid Interaction, Fixed geometry Physics. If not then which connection I can use for applying rotating load on the inner surface SFD. Any suggestion will be helpful for me.
2 Replies Last Post 30 août 2018, 15:54 UTC+2
Posted: 7 years ago 24 août 2018, 09:49 UTC+2
Fliud-Structure Interaction, Fixed Geometry contains a full Solid Mechanics interface, so you have access to any feature there, including Rigid Connector.
Henrik
Henrik Sönnerlind
COMSOL
Hi, **Fliud-Structure Interaction, Fixed Geometry** contains a full **Solid Mechanics** interface, so you have access to any feature there, including **Rigid Connector**. Regards, Henrik
Posted: 7 years ago 30 août 2018, 15:54 UTC+2
Thanks Dear Henrik.
Regards Anurag
Thanks Dear Henrik. Regards Anurag
