Amorphous Silicon under electron impact: in-bulk electron-hole pair formation, and secondary electron emission (SEE)
Hello all!
Here is what I want to simulate, first in 2D. A 500 keV electron (let's say coming from the right) hits an amorphous silicon surface, creating many electron-hole pair inside the amorphous silicon. Some of these electrons are ejected back outside the amorphous silicon. The whole system is put inside a constant homogeneous top-down electric field to separate the electron-hole pair.
I just want to start right. My question is: which physics & coupling should I use for better results? Here is what I wanted to try next week:
-> For the single primary electron: charged particle tracing (cpt) (and the trajectory will be a little bent because of the coupling with the electric field),
-> For the constant electric field: electrostatics (es),
-> For the electron-hole pair behavior inside the amorphous silicon: plasma (plas) (although it's not plasma, coupled with the electric field, like in the dielectric barrier discharge tuto example),
-> But what should I use to provoke an e-/h+ pair creation when my incoming electron hits the amorphous silicon?
-> For the secondary electrons exciting the silicon: nothing, as they are the product of the previous coupling.
Would all that be a good start?
Another quick question: amorphous silicon is not included in my material list. I can define it, but is there a quicker way to import this material?
Thank you very much.
2 Replies Last Post 6 sept. 2018, 05:45 UTC−4
Posted: 7 years ago 3 sept. 2018, 10:08 UTC−4
Hello!
Just for an update. I started with Charged Particles Trajectories (cpt), input the secondary electrons emission upon the "frozen-at-boundary" primary electron. The electron-hole pair behavior can be well described thanks to the "Semiconductors" physics.
However, I can't find the e-/h+ pair creation upon incoming electron on silicon. Someone would have any idea? Has someone already modeled this kind of interaction?
Thank you for your answer.
Hello! Just for an update. I started with *Charged Particles Trajectories (cpt)*, input the secondary electrons emission upon the "frozen-at-boundary" primary electron. The electron-hole pair behavior can be well described thanks to the "Semiconductors" physics. However, I can't find the e-/h+ pair creation upon incoming electron on silicon. Someone would have any idea? Has someone already modeled this kind of interaction? Thank you for your answer.
Posted: 7 years ago 6 sept. 2018, 05:45 UTC−4
Hello there!
I tried reposting. Please follow the other thread here and consider this one void.
Hello there! I tried reposting. Please follow the other thread [here](https://www.comsol.com/forum/thread/206641/electron-beam-induced-current-in-silicon) and consider this one void.
