6 juil. 2011, 18:40 UTC−4
Please send ur model so we Can help u ...
8 juil. 2011, 10:07 UTC−4
Hi sam,
please find the attachment. stationary and time dependent studies are working properly.
but coupling two solution is not successful.
kind regards,
Mohammad
Hi sam,
kind regards,
Mohammad
20 juil. 2011, 15:01 UTC−4
In fact U have to treat ur own Equations ... I don't know what is the physics but i am sure u can change to have only one Equation and one study as stationary study is a specific case of time dependent (in my opinion).
20 juil. 2011, 17:02 UTC−4
Solve transient problem, store solution. Then in solver manager, solve stationary problem with initial value setting, initial value evaluated using stored solution
19 sept. 2011, 13:55 UTC−4
Hello Mohamad,
could you please let me know if you had solved the problem? I am working on similar problem. Also are you using COMSOL 3.5a?
Hello Mohamad,
25 sept. 2011, 15:36 UTC−4
hi Subhra,
yes i've found the soluiton. I'm working with 4.2
hi Subhra,
4 oct. 2011, 06:12 UTC−4
Hey Mohamad,
and how did you solve the problem? I have a similar problem, so it might help to know what you did.
Regards
Hannah
Hey Mohamad,
Regards
Hannah
4 oct. 2011, 06:34 UTC−4
hi Hannah,
you can set two studies, first stationary and then time dependent. choose solver at the time dependent solver, afterwards select dependent variables, u can set the input parameters from another solver.
goo luck,
Mohammad
hi Hannah,
goo luck,
Mohammad
4 oct. 2011, 07:36 UTC−4
Thanks Mohamad!!
Thanks Mohamad!!
10 years ago
28 mars 2015, 18:01 UTC−4
Hello, Mohammad
Would you please send your successful coupling file to me? I have the same problem. Many thanks.
Lanju
Hello, Mohammad
Lanju
