How to assign a 2D random function as porous matrix property (porosity)
Good morning,
I really need your help, because I can't find anything in the help files.
I have a model using the the Brinkman Equations module for 2 dimensional porous media flow.
I want the porosity of the matrix to variate around the mean value of 0.5, so I defined a 2 dimensional random function named rn1 to describe this.
Now my problem is, that I can't define the porosity in the porous matrix properties as this rn function. I suspect, there is some kind of special "term" I have to use.
It would be great if you could help me!
Thank's a lot!
Jaques
4 Replies Last Post 4 juil. 2017, 09:23 UTC−4
Posted: 1 decade ago 4 juil. 2011, 02:11 UTC−4
It would be great, if someone helps me with this problem. I'm stuck for about 2 days now.
Posted: 1 decade ago 31 mai 2013, 15:05 UTC−4
Hi Jaques,
I have the same exact problem. I'm trying to simulate a random distribution of Quantum Dots in a dielectric material.
It looks like the graphics objects don't want to work with externally defined functions.
Did you ever solve it?
Hi Jaques, I have the same exact problem. I'm trying to simulate a random distribution of Quantum Dots in a dielectric material. It looks like the graphics objects don't want to work with externally defined functions. Did you ever solve it?
Posted: 8 years ago 4 juil. 2017, 07:17 UTC−4
Hi Tal,
Did you solve the problem?
I met the same problem with now.
Hi Tal, Did you solve the problem? I met the same problem with now. Thanks
Magnus Ringh COMSOL Employee
Posted: 8 years ago 4 juil. 2017, 09:23 UTC−4
It works, if you call it using "component syntax" in the text field for a user-defined porosity, such as
comp1.rn1(x[1/m],y[1/m])
if you have added a Random function called rn1 in Component 1 (comp1). The [1/m] syntax is used to make the input arguments dimensionless and hence avoid a warning about an unexpected unit of input.
Magnus Ringh, COMSOL
Hi, It works, if you call it using "component syntax" in the text field for a user-defined porosity, such as comp1.rn1(x[1/m],y[1/m]) if you have added a Random function called rn1 in Component 1 (comp1). The [1/m] syntax is used to make the input arguments dimensionless and hence avoid a warning about an unexpected unit of input. Best regards, Magnus Ringh, COMSOL
