7 years ago
26 juil. 2018, 15:12 UTC−4
Updated:
7 years ago
Hi Semih,
What do you mean you have to change the initial temperature?
If you want to couple two physics and use the solution of the first as an initial condition of the second you can go to "Study 1" in the first branch and check the "use solution as an initial condition" (something like that, can't remember the correct name now) and choose the solution you want.
Hope this helps.
Nichal
Hi Semih,
Hope this helps.
Nichal
7 years ago
26 juil. 2018, 16:15 UTC−4
Thank you for your interest. My question is that do I need to change initial temperature even if I calculate all initial value for 900 degC. I mean that I calculate the viscosity, density, volumetric flow rate and molar concentration according to 900 degC. Also, I added them manually. Hence, do I need to change initial temperature ?
7 years ago
26 juil. 2018, 16:22 UTC−4
Updated:
7 years ago
If they are two different physics and studies I would that you do, but maybe someone else could confirm it
