Jeff Hiller
COMSOL Employee
10 juin 2011, 20:48 UTC+2
There are tons of Finite Element Analysis books out there that explain this in great detail, but in a nutshell it boils down to this:
Say I give you a wildly varying function f(x) defined over a segment [a;b] and I ask you to approximate it with a single straight line. The approximation won't be too good, right? Now, I ask you to approximate it with two straight lines, one over [a; (a+b)/2] and one over [(a+b)/2; b]. You'll be able to get a better approximation, but it still won't be very good, right? Now, continue this process: you're allowed 3 segments, then 4, then 5, etc. Your approximation will get better and better each time. With FEA, it's basically the same thing: the more degrees of freedom you have in a mesh, the closer you can approximate the actual solution of the PDEs that you're solving.
10 juin 2011, 21:29 UTC+2
Thanks so much.
[QUOTE]
[/QUOTE]
Thanks so much.
