Matlab LiveLink
Hi guys... I am physics student and really begginer at comsol. I need to provide post processing by matlab livelink . when I try to open my comsol prj at matlab , I see a message which says I can just read data from comsol prj :
Warning: The file "C:\Program Files\COMSOL\COMSOL53a\Multiphysics\applications\LiveLink_for_MATLAB\Tutorials\homogenization_llmatlab.mph" is read-only
what is the problem ?
3 Replies Last Post 27 juil. 2018, 10:57 UTC−4
Posted: 7 years ago 26 juil. 2018, 08:33 UTC−4
Hi Mohammad,
Did you open the "COMSOL with Livelink" program or just the "COMSOL"?
Nichal
Hi Mohammad, Did you open the "COMSOL with Livelink" program or just the "COMSOL"? Best, Nichal
Posted: 7 years ago 27 juil. 2018, 10:30 UTC−4
Hi Nichal
I open the Comsol With Matlab program at the first step, then I open a specific comsol program ( e.g : prj1.mph ) at the second step . when I write the command "mphopen" in "matlab command window" and select the comsol project( prj1.mph) , it shows : warning : the file is read only
This is exactly what I wrote and got :
mphopen Warning: The file "D:\comsol\projects\prj1.mph" is read-only The COMSOL model is now accessible using the variable 'model'.
Thannks for your consideration,
Mohammad
Hi Nichal I open the Comsol With Matlab program at the first step, then I open a specific comsol program ( e.g : prj1.mph ) at the second step . when I write the command "mphopen" in "matlab command window" and select the comsol project( prj1.mph) , it shows : warning : the file is read only This is exactly what I wrote and got : >> mphopen Warning: The file "D:\comsol\projects\prj1.mph" is read-only The COMSOL model is now accessible using the variable 'model'. Thannks for your consideration, Mohammad
Posted: 7 years ago 27 juil. 2018, 10:57 UTC−4
I am afraid I can not help more than trying to guess because I just recently start to work with livelink...
Here are some suggestions though: -> if you are using linux start livelink using the command: comsol server matlab -> if you are using a computador that is not yours check the permission of the folder where you saved the file -> try to save the file in another folder and see if it helps -> if the .mph file is not yours check the permissions of it within COMSOL
Hope any of these help you Mohammad
Nichal
I am afraid I can not help more than trying to guess because I just recently start to work with livelink... Here are some suggestions though: -> if you are using linux start livelink using the command: comsol server matlab -> if you are using a computador that is not yours check the permission of the folder where you saved the file -> try to save the file in another folder and see if it helps -> if the .mph file is not yours check the permissions of it within COMSOL Hope any of these help you Mohammad Best, Nichal
