6 juin 2011, 10:58 UTC−4
thats funny, have you tried the wireframe mode ?
It could be linked to your graphical card if it's really a SW/HW issue, for me its OK
6 juin 2011, 11:28 UTC−4
transparency works for me as well. You might try the different 3D rendering methods OpenGL, DirectX and software rendering.
Cheers
Edgar
Cheers
Edgar
8 juin 2011, 08:57 UTC−4
Hi Guys,
I have the same problem here:
the surface plot of the temperature for the busbar example with air stream for cooling DOES NOT display correctly with transparency turned ON.
However, if you make a snapshot of the graphic the exported image is correct and shows transparency.
I am using a 2011 Macbook Pro with a Quad Core i7 and a AMD Radeon HD 6750M with 1GB memory and 8GB main memory.
Honestly, I am quite upset that there is this glitch in the graphics. How do we report this bug?
Someone mentioned changing the rendering options? How do I do that?
junis
Hi Guys,
junis
8 juin 2011, 09:03 UTC−4
OK, software rendering solves the problem, but that is clearly not the point of having a graphics card.
To COMSOL: please fix this!
8 juin 2011, 09:19 UTC−4
no use to report these kind of bugs only here, as we are mostly users as you are.
Send a detailed description to "support" they can take care of this, we others out herecannot do much, apart for being warned, always interesting ;
it could be a java issue too anyhow
9 years ago
1 oct. 2015, 13:34 UTC−4
I am facing the same problem ,please help me out.
