Domain numbers
Is there a way to specify subdomain numbers for geometries in the matlab interface. I need to move geometries around and the domain numbers keep changing as i move the geometries, which changes material parameters (equ.ind).
1 Reply Last Post 27 nov. 2009, 15:13 UTC−5
Posted: 1 decade ago 27 nov. 2009, 15:13 UTC−5
following the way the boundaries and volumes are mapped is no easy task, you have some of the options in he description of "geomanalyse" that gives you the correspondance vectors, but its quite some work to sort them out.
Try a search field "numbering" in the forum search, there has been a couple of discussion around this before
Hi following the way the boundaries and volumes are mapped is no easy task, you have some of the options in he description of "geomanalyse" that gives you the correspondance vectors, but its quite some work to sort them out. Try a search field "numbering" in the forum search, there has been a couple of discussion around this before Good luck Ivar
