difference between eigenfrequency and frequency .
hi
can anyone explain what is the difference between eigenfrequency and frequency .
let us consider an eigenfrequency : 2.34567e5i or 4.87965e7 + 2.567e8i
so what will be frequency in both case .?
4 Replies Last Post 30 mai 2011, 04:27 UTC−4
Posted: 1 decade ago 27 mai 2011, 07:59 UTC−4
an eigenfrequency is a special case of an eigenvalue, which is a general mathematical term. You can have a look at en.wikipedia.org/wiki/Eigenvalues_and_eigenvectors
Cheers
Edgar
Hi, an eigenfrequency is a special case of an eigenvalue, which is a general mathematical term. You can have a look at http://en.wikipedia.org/wiki/Eigenvalues_and_eigenvectors Cheers Edgar
Posted: 1 decade ago 28 mai 2011, 01:21 UTC−4
thank u sir for ur reply
ya i understood in general what is eigenfrequency but
while simulating(comsol model) my model i am getting some eigenfrequency which is complex.
but i need resonant frequency in order to calculate Q factor
so how can i extract that frequency from eigenfrequency.
needed the help
waiting for ur reply sir
thank u sir for ur reply ya i understood in general what is eigenfrequency but while simulating(comsol model) my model i am getting some eigenfrequency which is complex. but i need resonant frequency in order to calculate Q factor so how can i extract that frequency from eigenfrequency. needed the help waiting for ur reply sir
Posted: 1 decade ago 30 mai 2011, 01:43 UTC−4
another point I believe you are referring to is that complex frequency values means that you have damping, hence you should rather use Bodee plots with amplitude phase information (with abs() and atan2(imag(),real()) operators)
when you do a frequency domain plot, you will see that COMSOL proposes equations for the physics that are derived as harmonic time developments. While if you choose eigenfrequency, its the "classical" matrix eigenvalue that is used
Hi another point I believe you are referring to is that complex frequency values means that you have damping, hence you should rather use Bodee plots with amplitude phase information (with abs() and atan2(imag(),real()) operators) when you do a frequency domain plot, you will see that COMSOL proposes equations for the physics that are derived as harmonic time developments. While if you choose eigenfrequency, its the "classical" matrix eigenvalue that is used -- Good luck Ivar
Posted: 1 decade ago 30 mai 2011, 04:27 UTC−4
to my knowledge in a complex eigenfrequency the real part stands for the system's resonance frequency in the undamped case and the imaginary part stands for the damping.
So, the imaginary part is already a measure for the quality.
If you kick such a system with a real part omega and imaginary part delta with delta << omega (damping is small) it will oscillate with the frequency sqrt(omega^2 - delta^2), which is lower than the undamped eigenfrequency.
Cheers
Edgar
Hi, to my knowledge in a complex eigenfrequency the real part stands for the system's resonance frequency in the undamped case and the imaginary part stands for the damping. So, the imaginary part is already a measure for the quality. If you kick such a system with a real part omega and imaginary part delta with delta
