Arbitrary constitutive model
I am wondering if it is possible to model a material with arbitrary constitutive relationship in the structural mechanics module. For example, if I want to model a material whose stress matrix depends on the strain matrix in an arbitrary way, how do I specify that dependence?
Thanks in advance for any help.
Deb
3 Replies Last Post 30 mai 2011, 01:11 UTC−4
Posted: 1 decade ago 24 mai 2011, 01:29 UTC−4
but isn't that the definition of an anisotropic material with a D tensor instead of scalar E and nu modulus
Hi but isn't that the definition of an anisotropic material with a D tensor instead of scalar E and nu modulus -- Good luck Ivar
Posted: 1 decade ago 26 mai 2011, 11:30 UTC−4
Thanks, Ivar. Yes, I can do that. But it would be simpler if I could model the material using a strain energy function. Do you think COMSOL allows us to write the constitutive equation in terms of a strain energy function?
Deb
Thanks, Ivar. Yes, I can do that. But it would be simpler if I could model the material using a strain energy function. Do you think COMSOL allows us to write the constitutive equation in terms of a strain energy function? Thanks, Deb
Posted: 1 decade ago 30 mai 2011, 01:11 UTC−4
check the doc for the different material properties, there are other than just the "linear elastic"
Hi check the doc for the different material properties, there are other than just the "linear elastic" -- Good luck Ivar
