Boundary integration for a range of time
Hello everyone!
I have a doubt analyzing my postprocesing data. I´m simulating 4 walls like a room in 3D with radiative heat flux and ambient temperature whose change along the day in the heat transfer module in COMSOL 3.5a, so i´ve normal heat flux inside my walls in 24 hours in periods the one to one hour. I used the postprocessing menu the boundary integration but the integration is for a specific time... and my question is if i can do the integral of heat flux of one wall by the way, for example for a range of 1 to 4 hours... is it possible???
I really apprecite some advice,
Thank you,
Ivette. =)
2 Replies Last Post 24 mai 2011, 14:26 UTC−4
Posted: 1 decade ago 24 mai 2011, 01:48 UTC−4
check to KB (knowledge Base of COMSOl) I believe to remember its described therein, it has been addresses a few time son the Forum already
Hi check to KB (knowledge Base of COMSOl) I believe to remember its described therein, it has been addresses a few time son the Forum already -- Good luck Ivar
Posted: 1 decade ago 24 mai 2011, 14:26 UTC−4
Thank you very much Ivar... I'll check it
Ivette.
Thank you very much Ivar... I'll check it Ivette.
