What is the distance between a particle and the patterned wall
Posted 11 avr. 2018, 17:39 UTC−4 0 Replies
I am trying to simulate the particle deposition via COMSOL and I need to know the distance between a particle and a wall with periodic prism surface patterns. I know that the particle degrees of freedom are given the variable names qx, qy, and qz at Particle tracing for fluid flow at COMSOL but I have to define a force between a particle and the patterned wall surface which is depend on the distance between the particles and the patterned wall.
Thank you so much for your time in advance.
Hello Ali Mohammadtabar
