AutoCAD import error
Posted 2 avr. 2018, 08:04 UTC−4 CAD Import & LiveLink™ Products for CAD, Geometry Version 5.3a 2 Replies
Hi everyone,
I've been using AutoCAD to draw a model in 3D which would be extremely difficult to draw in Comsol (weird curves) but before importing that, I tried doing a test run since I've never imported into Comsol before; I drew a simple cube with dimensions roughly 1m long in AutoCAD, created a blank new model in Comsol and used the import function in geometry to choose this .dwg file (the file showed up when browsing so I assume the file type is importable). When clicking on import however, the following message pops up:
"Internal error translating CAD model. - Detail: Failure - Filename: C:\blahblahblah.dwg"
The simple cube model itself surely can't be the problem so there must be some options I need to play about with for importing I assume? If anyone has any idea what these options might be or if there's something else to be done then I'd really appreciate the help.
Thanks!
