25 avr. 2011, 09:54 UTC−4
what physical phenomena in COMSOL will give you some stiction ? I'm not sure there is any, by default so you must probably define something yourself.
Another point, passing the pull in value is tricky for the solver. Its easier to use pressure to make the contact, as this is linear
Nagi Elabbasi
Facebook Reality Labs
26 avr. 2011, 00:00 UTC−4
If by stiction you mean a static coefficient of friction that is higher than the dynamic coefficient then the COMSOL friction input already supports that feature. It should work for the cylinder example you mentioned.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
26 avr. 2011, 00:46 UTC−4
indeed, if we work tangentially, if we pull normally as a cantilever in contact will do, I'm not sure that is enough. In MEMS devices there are also van der Walls forces and other phenomena acting too
26 avr. 2011, 01:41 UTC−4
thanks for your reply. Actually I'm trying to figure out how can I make it work but I do have a couple of issues. In first place when I apply an upwards mechanical load the beam does not deattach from the substrate. I tried to use the static friction feature in the contact pair but the solver does not work. If I try to use an initial pressure it does not work either. I'm attaching my model.
Thanks for your help!
greetings
greetings
