Basic Parallel Plate Capacitor 3.5a - Integration Error
I am trying to create a very simple model to test the integration tools in COMSOL 3.5 (I have 4.1 as well but the lack of perfect electric insulation in AD/DC mode makes this program less accessible - if this is possible, please let me know).
I have created a simple rectangle with dimensions of 1m x 1m x 1m and have placed a constant potential of 1V on one edge and a ground on the other. The remaining two parallel sides are electric insulation. Finally, the subdomain has been set as "air" so that the permittivity is e0.
When I solve this geometry and try to perform a normal current density boundary integral on either of the conductive boundaries, I am off by a factor of 100*pi.
Any insight or suggestions would be helpful,
Patrick
1 Reply Last Post 19 avr. 2011, 10:59 UTC−4
Posted: 1 decade ago 19 avr. 2011, 10:59 UTC−4
You have an application mode with electric currents, but your "air" domain has "0" conductivity. I would not expect a large current then if you integrate over whatever area. And edges/boundaries inherit from the domains.
then why does 4.1 work, for me it has more options than 3.5 by now ?
Hi You have an application mode with electric currents, but your "air" domain has "0" conductivity. I would not expect a large current then if you integrate over whatever area. And edges/boundaries inherit from the domains. then why does 4.1 work, for me it has more options than 3.5 by now ? -- Good luck Ivar
