Dear ivar, heat transfer and volume fraction coupling.
Dear ivar, i am a comsol 4.0 user
and i want to couple the transient heat transfer and volume fraction below
Transient 1-D heat transfer : rho*cp*(dT/dt)=d/dx(k*(dT/dx))+Source term-rho*latentheat*(df/dt)
f : liquid fraction from PDE module
PDE : df/dt=f*gamma(T)
I took the source term value in Transient 1-D heat transfer "-rho*latentheat*(df/dt)" as
-rho*latentheat*ft
and In PDE module I took all zeroes in the spatial derivatives.
but it was not the data I expected.(especially, there was no difference between only Heattransfer and Heat transfer and PDE coupling)
please help..
any comment will be very appreciated . Thank you!
1 Reply Last Post 18 avr. 2011, 07:38 UTC−4
Posted: 1 decade ago 18 avr. 2011, 07:38 UTC−4
I'm not sure I'm catching everything, and you are in a physics mode I not that familiar with.
What I can say though is that if "f" is defined as a "dependent variable" for a particular "physics", and you are solving in transient mode (hence including "t") then "ft" = df/dt is indeed the time derivative of f, just like "fx,fy,fz" are the components of the spatial derrivatives of "f" (in 3D as all might not apply for your case)
Hi I'm not sure I'm catching everything, and you are in a physics mode I not that familiar with. What I can say though is that if "f" is defined as a "dependent variable" for a particular "physics", and you are solving in transient mode (hence including "t") then "ft" = df/dt is indeed the time derivative of f, just like "fx,fy,fz" are the components of the spatial derrivatives of "f" (in 3D as all might not apply for your case) -- Good luck Ivar
