Material properties as a function
Im trying to give youngs modulus for a material as a function of three different variable say a,b,c where a is in [Pa] and b is in [Pa] and c is a constant..How to i define an analytic function and write the expression in the actual space given for youngs modulus?Example my analytic function is ((a)/1+((b/a)-1)*(c)).
2 Replies Last Post 23 mars 2018, 00:49 UTC−4
Posted: 7 years ago 28 févr. 2018, 09:43 UTC−5
On the Material definition node, and inside a property group, an analytical function can be added (see the picture) And the value of the parameter is specified in the 'Material Contents' Value colums, or in the property group definition. You can change it to the name of your function
The 'Model inputs' parameters of the function can also be specified on the 'property group' definition, I think in order to deals with different notation
best regards,
On the Material definition node, and inside a property group, an analytical function can be added (see the picture) And the value of the parameter is specified in the 'Material Contents' Value colums, or in the property group definition. You can change it to the name of your function The 'Model inputs' parameters of the function can also be specified on the 'property group' definition, I think in order to deals with different notation best regards,
Posted: 7 years ago 23 mars 2018, 00:49 UTC−4
How can i give youngs modulus as a function of temperature and initial stress?.Can anyone post the screenshot of it containing all the arguments and the units?
