how to decrease the inteface thickness in level set method
Dear friends,
I want to somehow decreases the interface thickness of two immiscible fluids in level set method. cause when I get the results I get some regions near the interface of the two immiscible fluids that have both fluids in it and it does not make sense as we have two immiscible fluids.
How can I do this ? I have tried by lowering the epsilon parameter in level set configuration but it takes much more time to converge when I decrease the epsilon parameter. what should i do ???
1 Reply Last Post 30 janv. 2017, 13:25 UTC−5
Hello Osameh Ghazian
Posted: 8 years ago 30 janv. 2017, 13:25 UTC−5
Did you find any solution to your problem?
Raja Barnwal
Hi Did you find any solution to your problem? -- Raja Barnwal
