Regarding Microresistor beam example in COMSOL Multiphysics 4.0a
I had a question regarding microresistor beam example in MEMS module:
Copper is used in this example. Can aluminium be used in microresistor beam ?
Are there any advantages or disadvantages if we use aluminium instead of copper?
Please provide me an answer for this.
Thank you
1 Reply Last Post 6 avr. 2011, 09:24 UTC−4
Posted: 1 decade ago 6 avr. 2011, 09:24 UTC−4
what are you looking for ? the resistivity ? then check the material data, idem for stiffness and heat capacity properties.
But the main reason I believe is a technological reason, from my knowledge it's easier to deposit Cu than Al, either electrochemically or via soldering
Hi what are you looking for ? the resistivity ? then check the material data, idem for stiffness and heat capacity properties. But the main reason I believe is a technological reason, from my knowledge it's easier to deposit Cu than Al, either electrochemically or via soldering -- Good luck Ivar
