3D rototating disk
Posted 5 avr. 2011, 14:45 UTC−4 Fluid & Heat, Computational Fluid Dynamics (CFD) 1 Reply
hi
I'm probably just missing something obvious.... but
in v 4.0 I haven't been able to get a 3D rotating disk laminar flow working
similar to the 2D example given (which works fine)
I have the 3D model built - no problem.
but when it comes to assigning the sliding wall parameters to the disk - I can only find the x/y components
which seems to work just tickity boo - if that was what was wanted.
how do I persuade the disk surface to think it is rotating about z?
the doc says:
"About Cylindrical Coordinate Systems
A Cylindrical Coordinate System may be used in 2D and 3D where rotational symmetry about the axis is required. Note that the cylindrical coordinate system is not applicable in geometries with 2D axisymmetry."
I defined a cylindrical coordinate system.... but can't figure out to tell the program to use it
do I have to resort to something messy like moving mesh?
the doc says:
1 Reply Last Post 6 avr. 2011, 01:34 UTC−4
