Sweep forms a grid
I am new to Comsol and know very little about different features of the software. When I want to form a grid by sweeping, the software prompts for an unsupported link surface topology. what should I do? thank you.
1 Reply Last Post 21 déc. 2017, 16:32 UTC−5
Posted: 7 years ago 21 déc. 2017, 16:32 UTC−5
Swept meshing is a powerful technique but it requires that several condition be met. You will find them listed in the Reference Manual for COMSOL Multiphysics, version 5.3a, page 556. All manuals are accessible through File > Help > Documentation.
The error message suggests that you may be in a situation similar to the example on page 546 of that same manual, in which case the same type of virtual operation discussed there may apply to your work as well. It's hard to say for sure without having access to your .mph file.
Jeff Hiller
Swept meshing is a powerful technique but it requires that several condition be met. You will find them listed in the Reference Manual for COMSOL Multiphysics, version 5.3a, page 556. All manuals are accessible through File > Help > Documentation. The error message suggests that you may be in a situation similar to the example on page 546 of that same manual, in which case the same type of virtual operation discussed there may apply to your work as well. It's hard to say for sure without having access to your .mph file. Best regards, Jeff
