Why the results are different so much by tow modelling methods in simulating the temperature field of laser-remelting
Posted 28 mars 2011, 23:19 UTC−4 Mesh, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers 1 Reply
Dear Ivar
Now, I am simulating the temperature field of laser-remelting. Two methods are adopted to realize the heat source moving:
1) the center coordinate of the laser spot is a function of time, and a constant heat flux is added on the laser spot area. Say, (X0, Y0) denotes the center of laser spot and r the redius of laser spot, a constant heat flux is added on the surface area of sqrt((x-X0)^2+(y-Y0)^2)<=r.
2)fix the coordinate in the center of laser spot and add the moving velocity into the PDE, heat flux is added on a fixed circle area with redius of r.
The same parameters and meshing was setted. However, the results was very different with each other. The spot center temperature of method 1) is far lower than the one of method 2) and the temperature field in spot is not smooth. Meanwhile, the result of method 1) is affected by the mesh size.
May be, the node number in the spot area is the reason? I don't know why. And how to resolve the problem in method 1)?
Please give me some help.
1 Reply Last Post 29 mars 2011, 02:19 UTC−4
