Time dependent problem, never getting a solution
Hi everybody,
I want to solve a navier stokes and heat transfer problem transiently.
There are weak boundary terms and ALE as well..
When I press on the solve button I have endless runs without even getting a time value different from zero..
The solver assembles the matrice and solves the linear system but the time value never increases.
What is the problem here?
Can somebody help me?
1 Reply Last Post 26 mars 2011, 04:03 UTC−4
Posted: 1 decade ago 26 mars 2011, 04:03 UTC−4
my suggestion is to check the initial conditions, they may be too far from the final result, put some velocity, pressure drop, temeprature field, just a first guess, it often helps to set the gradients, then the sover might finds a better direction to start with, than a all flat "0"
Hi my suggestion is to check the initial conditions, they may be too far from the final result, put some velocity, pressure drop, temeprature field, just a first guess, it often helps to set the gradients, then the sover might finds a better direction to start with, than a all flat "0" -- Good luck Ivar
