geometry properties in models
Posted 10 nov. 2009, 13:21 UTC−5 0 Replies
Dear all,
currently the model is two curved surfaces near each other (the distance between the curved surfaces are not uniform, I need the shortest distance between the two curves to evaluate an expression at each boundary point. I have searched the documentation and as these curves will eventually come into contact I have defined them as a contact pair. I assumed the variable gap_cp1 (its 1 in my model) would hold the distance but it fails to evaluate. Any suggestions or examples in using gap_cp1, or a way of getting the x,y,z coordinates of the point on the nearest surface would be appricated.
The region between the two surfaces is not meshed.
Thank you
Rizgar Mella
Hello Rizgar Mella
