Reciprocal of step size
Hello!
My question is how I can get current value of 'Reciprocal of step size' that convergence plot uses. The value normally plotted during calculation in COMSOL window, therefore I think may be the value can be get using some expression. If I know the expression, I'd like to use it for STOP condition. Thank you. Have a nice day.
Hideki
2 Replies Last Post 28 oct. 2017, 10:23 UTC−4
Magnus Ringh COMSOL Employee
Posted: 7 years ago 16 oct. 2017, 04:15 UTC−4
The current step size is available as a variable, timestep, which you can use in a step condition. The step condition can be any Boolean expression, so you could use something like
(1/stepsize) < 100
for example, if you want the time stepping to stop when the reciprocal step size drops below 100.
Best regards, Magnus Ringh, COMSOL
Hi, The current step size is available as a variable, timestep, which you can use in a step condition. The step condition can be any Boolean expression, so you could use something like (1/stepsize) < 100 for example, if you want the time stepping to stop when the reciprocal step size drops below 100. Best regards, Magnus Ringh, COMSOL
Posted: 7 years ago 28 oct. 2017, 10:23 UTC−4
Dear Ringh-san,
Thank you very much! I will try it.
Hideki Masuda
Dear Ringh-san, Thank you very much! I will try it. Hideki Masuda
