make the edge of composite object more smooth
Hello:
I have a simple question about drawing the shape
step1: draw a sphere
step2:draw a cylinder
step3:select all
step4; choose " difference"
but I want to make the edge of composite more smooth so that it is not sharp shape
more details in the attachment
Thank you for your help
2 Replies Last Post 4 déc. 2015, 10:10 UTC−5
Posted: 1 decade ago 20 mars 2011, 15:30 UTC−4
you have no fillet options in 3D within COMSOL (you need to use an external CAD programme then. But you can do , in COMSOL, define a workplane, draw a circle, a cut line or a rectangle then make the difference and finally fillet the sharp edge. Then you perform a revolve to get the 3D shape. Have a try
Hi you have no fillet options in 3D within COMSOL (you need to use an external CAD programme then. But you can do , in COMSOL, define a workplane, draw a circle, a cut line or a rectangle then make the difference and finally fillet the sharp edge. Then you perform a revolve to get the 3D shape. Have a try -- Good luck Ivar
Posted: 9 years ago 4 déc. 2015, 10:10 UTC−5
Update on this thread: Nowadays COMSOL does include a direct 3D filleting capability in the Design Module. See www.comsol.com/design-module
Update on this thread: Nowadays COMSOL does include a direct 3D filleting capability in the Design Module. See www.comsol.com/design-module Best, Jeff
