conservative phase field method
Posted 17 mars 2011, 10:51 UTC−4 Fluid & Heat Version 4.0a 1 Reply
hi friends,
what are the differences between the conservative and non conservative form of the phase field method in two phase flow in comsol ?
I want to model a water droplet in oil and it works with non conservative form of phase field but when I changed the settings from non conservative to conservative, the droplet disappear and I get some results that can not be defined by physics.
I thought that the conservative form must conserve the mass better than non conservative form, but I get the worse results with conservative form , why ?
I want a method that conserve the mass the most.
1 Reply Last Post 27 mars 2011, 20:50 UTC−4
