Polymer thermal stress analysis, error: Out of memory during assembly
Posted 14 sept. 2017, 10:38 UTC−4 Structural & Acoustics, Heat Transfer & Phase Change Version 5.3 1 Reply
Dear all,
I have confronted a problem when I wanted to simulate the polymer cooling process with "thermal stress" simulation. The Error showed: Out of memory during assembly. I noticed that the comsuming RAM was increasing quite fast when the simulation starts, then the RAM memory is not enough. I noticed that when I just simulate the thermal process, everthing was good. Only when coupling with the Solid Mechanics study, the problem happened. Could anyone give me some suggestions about the reason? I would assume it to be BC setting or multiphysics coupling. I would attacht the model here as well. Thanks!
