Postprocessing: Skewed scales on 2D plots
I have 2-D porous media model that I use to run flow and transport simulations (Laminar Flow and Transport of Diluted Species modules, respectively). The simulations works very well. However, the problem is in the post-processing.
The domain is a rectangle: 7.4 cm long by 1.5 cm high. Most of the time when I view 2D plots (surface plots), the spacing in the x and y directions are equal (i.e. the scales are the same so the domain looks like the rectangle that it is). But, other times, the scales are skewed such that it plots my domain into a square! This problem comes up without any reason as far as I can tell. I will be using the same model and it will plot things with the correct scales, and then one time when I re-open the model and click on the 2D plot results, the skewed plot shows up.
I don't know why this happens and I can't seem to go back to have equal-scaled plots when the skewed results come up.
Any help would be much appreciated!
Thanks.
3 Replies Last Post 15 mars 2011, 12:29 UTC−4
Posted: 1 decade ago 15 mars 2011, 12:17 UTC−4
you have an option in the Definition - View node (or the sub-sub node) where you can select the option of fixed axis or free-scaled axis (the latter is very usefull in i.e. MEMS for thin features).
Sometimes, when you open a free-scale model the settings remain for another model, within the same GUI process. Check it out
Hi you have an option in the Definition - View node (or the sub-sub node) where you can select the option of fixed axis or free-scaled axis (the latter is very usefull in i.e. MEMS for thin features). Sometimes, when you open a free-scale model the settings remain for another model, within the same GUI process. Check it out -- Good luck Ivar
Posted: 1 decade ago 15 mars 2011, 12:26 UTC−4
Ah, this is good. In Definition -> View, I have the option to "Lock axis". And in the View subnode Axis, I have the option to "Preserve aspect ratio". I have selected both and this seems to have fixed the problem.
Thanks Ivar!
Ah, this is good. In Definition -> View, I have the option to "Lock axis". And in the View subnode Axis, I have the option to "Preserve aspect ratio". I have selected both and this seems to have fixed the problem. Thanks Ivar!
Posted: 1 decade ago 15 mars 2011, 12:29 UTC−4
It is, in fact, the "Preserve Aspect Ratio" that is important. The "Lock axis" can be a pain if you change the size of your graphics window...
