Linking Parametric and Material Sweep in COMSOL 5.2
I have a model in which both parametric sweep and material sweep are defined. Is it possible to compute the model, such that material and parametric sweep runs in parallel.
To explain more in detail, I have defined a range of values of parameter p1 (say 10 values) in parameter sweep and also defined 10 materials and added them to the material sweep. Now is it possible such that when the model is computed, for the first value of parameter, first material in the material sweep in considered and for the second value of the parameter second material is chosen and so on.
So far from what I browsed, I understand that these two can be done easily when taken one at a time.
Can someone help me in this issue.
Ashitosh
0 Replies Last Post 2 sept. 2017, 02:47 UTC−4
Hello Ashitosh Velamuri
