11 mars 2011, 08:13 UTC−5
the discontinuity issue is when you use such Dirac functions for the physics, then the solver might "jump over them"
perhaps if you use more (), or try a boolean
(x==0)*(T==300)*YourValue
11 mars 2011, 09:56 UTC−5
Hi Ivar,
Thanks for the quick reply.
I understand what you are saying.
However I wish to assign the variable xi to the value of x when T=300 and y=0.
So that if both T=300 and y=0 are true (then equal to one) then whatever the x coordinate at the point is gets assigned to xi.
If I use the expression you suggested then xi comes back with a value of 0.
I am trying to use an if statement to get the value I want but keep getting a value of 0 for xi:
if(T==300 && y == 0,xi == x)
I hope I have made my problem clear!
I would really appreciate some help!
-Adam
Hi Ivar,
-Adam
11 mars 2011, 11:06 UTC−5
then what about:
Your_value = (y==0)*(T==300)*(My_New_Value - Some_other_value) + Some_other_value
then what about:
11 mars 2011, 17:56 UTC−5
There are some descriptions about the if operator in the User's Guide. It said the expression is if(cond, expr1, expr2), I am not sure whether expr2 is necessary or not. You can see the Guide for details.
12 mars 2011, 04:36 UTC−5
there are two places whree aou can test out formulas:
- the parameter line that calcualtes out your value (and translates the units)
- the analytical function, whcih allows you quickly to plot a function. I mostly write my complex fomulas as functions, as then I can plot them easily to check how they look, its so easy to forget a sign, or an offset. Alwaysmverify and validate your work,in steps it's easier ;)
24 juil. 2012, 20:52 UTC−4
Are there any way to make a 2D function?
I can easily plot the function f=(x<= 5).
But how to plot a function f=(x<=5,y<=5) in a 2D plan.
Cheers,
Dao
25 juil. 2012, 02:09 UTC−4
have you tried the filter and (x<5)*(y>2) condition, or whatever Boolena condition you need ?
have you tried the filter and (x2) condition, or whatever Boolena condition you need ?
