how to calculate the impedance
I have modeled a semiconductor resistance to which i have applied a small signal voltage varying from 0 volts to 26 mV. by using the option of sub domain integration , i integrated the total normal current density to evaluate the small signal current. Now i would like to calculate the impedance. How can i achieve this?
3 Replies Last Post 10 mars 2011, 00:55 UTC−5
Posted: 1 decade ago 9 mars 2011, 13:55 UTC−5
if you have the voltage, and you integrate the current over the wire section you sould get te impedance by the ratio of V/I, but take care if you have complex values to get the right formula
Hi if you have the voltage, and you integrate the current over the wire section you sould get te impedance by the ratio of V/I, but take care if you have complex values to get the right formula -- Good luck Ivar
Posted: 1 decade ago 9 mars 2011, 22:31 UTC−5
I see that when i increase the frequency , the current is constantly increasing i.e. the impedance is constantly reducing which implies that there must be a capacitive component in the impedance. so i expect a phase lead in the current w.r.t to the voltage. is there a way by which i can see the current values? or plot the phase of the current ?
Posted: 1 decade ago 10 mars 2011, 00:55 UTC−5
3.5 is getting old in my mind, you might need to turn on the "might produce complex values" in the solver section
Hi 3.5 is getting old in my mind, you might need to turn on the "might produce complex values" in the solver section -- Good luck Ivar
